If youre saying you want to make molds for the vents that would be glassed into a hood later on…Id take the vents, and make the mold with the vent area blocked off so the mold had no holes.
Cut your cloth so that it didnt need to be cut out afterwards (still need to be trimmed Im guessing) and Id infuse them. The only problem I see is that youd need to be clever to infuse the bridges between the vents…resin can try to skirt areas on you when you infuse.
Although Im not sure why youd want to worry about it in the first place if youre going to make these as insert and blend peices…they will be getting worked pretty hard.
If the hood is one piece and youre going to make them for people you can just cut your cloth so the holes arent filled with cloth and tape off the area of the mold when you shoot gelcoat and peel it then do your thing…shouldnt be a problem.
