A bit of background: I’ve only recently started learning about composites design and manufacturing (for work and hobby). Up until now, I’ve only done epoxy laminating and have been reading about vacuum infusion. I’d really like to switch to vacuum infusion for the parts I’ve been making at home. One of the parts I’ve been using to learn the mold making and layup techniques on is an engine cover for my car. The image below shows a very simplified version of what I’m dealing with. The orange represents my mold surface/flanges. The black represents the part which will be made from CF. The light grey represents two aluminum inserts I have to mold in for mounting purposes.
I don’t really have an issue with getting the materials to lay into the mold properly and I understand the basic principles of vacuum infusion, but with this part, my concern is getting the resin to flow into the upright standoffs around the standoffs.
The bulk (flatter) of the part will be made with a 2x2 5.7oz Twill CF. The vertical cylinders will be formed with braided sleeves. I have planned on only using 5 layers of cloth since it is a cosmetic, non-load bearing component. Another thought was to use 2 layers, some sort of bulking flow media (Lantor Soric?), then two more layers.
Can anyone give me some pointers on how I should go about setting up to do an infusion? My initial thought was to run to feed lines directly on top of the standoffs and two vacuum lines, one on each far end of the part. But again, I’ve never done infusion before and I’m not sure how to set something like this up. Flat sheet, yeah, I think I can manage that but the standoffs are throwing me off.
Thanks.
