Thank you all for your usefull answers!
I’ve edited the opening post and added the url tot the image of the saddle.
And in this pdf file, from page 34, you can see more pictures of cf saddles. http://ax-lightness.de/nc/infocenter/downloads/?tx_abdownloads_pi1[action]=getviewclickeddownload&tx_abdownloads_pi1[uid]=106&tx_abdownloads_pi1[cid]=486
@Riff42
A few years back I’ve tried to build some straight 6mm thin walled tubes in a female mould using a bladder, but I never got a result that satisfied me… It seemed that the fibres where floating around in the mould, which made it hard to get an even thickness of the tube.
For these tubes it even gets harder because the tubes are curved and have thick walls.
The option of building the tubes from straight pieces which are glued togeher might be the simplest option, so I will keep that in mind.
@wyowindworks
Yes the tubes are load bearing. They connect the “saddle deck” to the saddle post. Together they have to carry at least 80kg, but it will be some more when I take the dynamic loads in account.
I really like the process you describe! I think I will give that a try.
I will keep you all updated about the progress!
