How to lay fiber cloth on these hood?
I want to duplicate these hood?
Any idea.
Thank you for any advise.
Weera
Any idea.
Weera
If You want fibers to look straight all round than you have to make it in parts. Frst lay stripes on the vents and than the big one over the entire bonnet, which You will cut in the middle around the vents. You just need to be careful with fiber orientation and to cut segments nicely. Easy with prepreg, or if you use dry fabric, simply laminate carbon to some fine fiberglass whith spray adhesive and than cut it by tampletes which You will useā¦
