Hey Guys,
So, I am attempting to make something quite simple.
Basically, I have a tube that I need to make a sleeve for. So, the tube serves as a mandrel/tool in this case and all is fine and easy so far.
One side (yeah, a circle has no sides…;-)) of the sleeve will be open (the sleeve doesn’t go all around the mandrel, but I am kinda asking for best practice on how to bag this?
Reason is, first try out of the bag showed a nasty wrinkle along the top of the sleeve. I think the bag pulled the laminate up into it’s own wrinkle.
I had placed the mandrel in the middle of the bag which led the bag to wrinkle in two places: The top where the laminate wrinkled too and the bottom which has no laminate so no problem there. (Not sure “wrinkle” is the right word for what the bag does. I mean, it’s the two places where the bag after having wrapped itself around the tube meets itself and flattens against the other side of the bag).
Is the solution to wrap the bag tightly around the mandrel so as to only have one wrinkle at the bottom, where the is no laminate? Is it this simple?
Any other tricks? Do you guys pull a low vac first and then “massage” the bag around and hopefully stretch back any laminate wrinkles the bag might have induced?
Thanks all, I’m on a few other forums (for other stuff) and this place rates very highly in manners, but most of all, genuine helpfulness!
