Just hoping to gain some input from people who have more experience than myself with this.
I’m just finishing up a few plugs and wondering how tight of a corner, or how sharp an edge it’s possible to make using wet layup? First up let’s say it’s just a straight up wet lay job, no sandwich moulds etc.
For example this one with the edges running along the top:
Fender Plug - Complete by mugget, on Flickr
I’ve sanded the tops of the edges down a little bit, but don’t want to paint the plug and make the mould just to find that I get bridging problems etc. when I go to make the first part. What kind of guideline would you use if you were making a part like this yourself?
As another example this part has a fairly crisp edge on the top that has been formed by working the top and sides.
under seat gap by mugget, on Flickr
I’ve since rounded it off a bit, but would like to know if there’s any way I could have left that edge?
And out of curiosity, with something like a sandwich mould with a 2nd mould part applied to the back of the job after layup, would that allow for a much sharper edge? Is it as simple as just holding down the area so it doesn’t bridge, or is there more to it?
Even better if anyone can share some photos showing the type of edges/corners/contours that you’ve been able to make using wet layup.
Cheers for any info!
