Extreme,
Awesome project! I make carbon fiber paddles for the Lamborghini Murcielago, LP640, and the SV670. I can’t show the molds (customer owned and contract) and although we are existing together in a similar market (potential conflict of interest) we are all family here on the forum… so here we go!
There are a couple of ways to make the mold (from what I’ve experienced). One way is to capture all of the edging detail in the mold resulting in less stress trimming the final piece, but resulting in a lot more technical layup.
The other way is to make the mold contour to the swoop of the paddle but somewhat flat (not really capturing the edging so much, and defining the trim by a scribe line in the mold face). Resulting in a very easy layup, but more attention needed when trimming.
With regards to the mounting hole recesses, it’s your preference… you can make the mold flat and countersink drill it post cure, or you can grab that detail in the mold and address the opposite side of the paddle post cure.
I found a way to make a multi-piece tool that captures both the front side and rear side of the paddle so that the composites are “smashed/sandwiched” in between the front and back side molds, then infused (sort or RTM Closed or RTM-Light).
Let me know if there is anything I can help you with, PM me if you’d like. Paddles are fun to make, they can be as easy or as complex as you want… which is sort of the fun of composites in the first place!
-Corban
