Evan - thanks for the tips!
I made my second try last night. Instead of using the polyester resin, I used epoxy resin (Aeropoxy). It was much easier to work with because of the longer pot life and more liquid characteristics. I tried laying up the fiber a little differently this time. Before, I was pouring resin into the mold and then laying up the fabric. I thought that would help me avoid surface voids. I was ending up with way too much resin, especially in the corners. That’s worked well for making molds, but not for making parts. Last nite, I went back the way of wetting the fiber on some poly plastic and flipping it over and putting it in the mold. Much less resin, but my part came out starved for resin (dry in spots).
I am currently experimenting with making household lightswitch covers because they are small, relatively flat, but have a little curvature to them. My biggest problem is just what you said - getting the fiber to lay down in the corners. I was hoping the vacuum would pull it to the corners, but I guess not. My best results have come from just putting a ‘caul plate’ on top of the fabric and using that to apply pressure. Is that the only way to get the fabric to lay down properly?
