After several test parts, failures and successes, and help from folks here, I was able to infuse my first “real” part, a 50" long by 12" ID cylinder, and it was complete success!
I am starting on another cylinder, but a bit larger, 75" long by 21" ID.
Can I /Should I add additional layers into the stack to increase stiffness?
If yes, how many could I add before it could create a problem with infusion resin flow?
Would I add more twill OR biaxial layers?
I used the Pro-Set INF 114 infusion epoxy (viscosity spec 100-200 cPa) and the infusion took about 20 minutes and was completely wet out WITHOUT voids or bubbles.
The previous stack from inside to out:
Mylar (to seal mandrel)
Peelply
1 layer, 6K 2x2 Twill 11.0oz/sq. yrd
1 layer, 6K 45deg biaxial 11.0oz/sq. yrd
1/4" Divinycell (perforated with 1/16" drill every 2" in a grid and scored across perforations)
peelply
red mesh
MTI hose/MTI Valve
vacuum bag
The approach was to use MTI hose to wrap each end of the tube at the resin break, connected by a single run along the top of the cylinder joining each end (one long piece of MTI hose) and infuse from the under side. I have pictures and video of the setup/process somewhere…
