This post was flagged by the community and is temporarily hidden.
The question you have posed can have a 1000 different answers,you will get a better answer if your more precise with your question
An Autoclave exerts higher than atmosphere pressure inside the pressure vessel. The part, under vacuum or vented to atmosphere has a lower differential of pressure consolidating the laminate inside the bag. Heat is added to cure the epoxy or other matrix. Cooling depends on the cycle you want. The effect would be a low void content, high fiber volume fraction part.
sounds like you need to contact a clave manufacturer. The sales rep should easily be able to answer all these questions and more. Everything you are asking about is variable and will depend on many factors.
