I am making a back for my NEV (neighborhood electric vehicle). I set it up with styrofoam and filled in the curves with expanding foam. Then I glassed the outside with 8oz fg and epoxy.
Now I need to make it smooth, but I’m scared that when it flexes, whatever I use will crack. I was planning on using bodyfiller, but will that crack?
Here are some pics.
I also am making this so that I can easily take it off and put it on when the weather is bad. So I wrapped the fg over the rollbars so I can fasten it down with something. The only thing I can thing of is drilling holes and tapping them and using regular bolts. There has to be something better (or cooler). Any suggestions?
BTW - I AM planning on cutting out a window hole and putting some sort of lexan or plexiglass so I can see in my rear view. And I’m also going to glass the inside.
