So this company is well known for their composite tanks. One thing that they claim is that their ranks are resistant to deterioration from fuels. This may be the case with race fuels (which is different then pump gas and commonly regarded as “harsher” but in reality from what my research has revealed is that there is nothing truly as harsh as oxygenated run of the mill pump gas (ie ethanol blends that have become ubiquitous).
FAA advises against any fuels with ethanol blends due to damage to engine components (aluminum and plastic/rubber components). Automotive components are no different and are subject to the same damage, injection system etc. Also the FAA advises against because of the increase in relative volatility and the decrease in energy per unit fuel.
anyways… any ideas how they would achieve a resistant tank without any liners or coatings?
quotes from their FAQ
Q. Will I have to drain my race fuel from my tank?
A. The epoxy matrix we use has never exhibited any problems with race fuels over extended periods of time.
Q. Do your tanks require a bladder and or do I have to apply a fuel proof coating on the inside such “Kreem”?
A. Neither. FuelCels are inherently fuel proof and leak free by creating an impervious shell matrix. In fact, a coating would have nothing to stick to and could peel off and get into your fuel system.
http://www.eti-fuelcel.com/order.html
Thanks.
my question is with your experience
