Ok, this is the first hood i have made. I did not have a mold so i just molded right off the topside of the plug.
I used 2 layers of 2oz fg mat. I vacuum bagged it at moderate pressure ( and I think i just found my problem ). I overlaid that fiberglass skin with one layer of 3k twill cf. topped it off with vinyl ester sprayed on. I notice now with the hood skin it is warped down in two areas.
By typing this i think i answered my own question… it warped because the hood plug sucked in on itself under vacuum.
Since I know there are folks on here that know more about molding… how would you make the mold for a hood skin?
I typically use VER and tooling gel coat. What lay up schedule can you recomend for a mold tool this size?
