Hi Everybody
I need to laminate the wingskin of a small non comercial aircraft.
I was thinking on the following laminate schedule as i would like to learn VIP technique while using Honeycomb.
Outer Laminate:
I infuse the whole wingskin with uni carbon aiming at 40% resin content.
Just after infusing I open the bag with care and roll/paint the same epoxy on the laminate where the honeycomb is going to be layed, but lets say at 10º or similar to avoid that the laminate absorbs the extra epoxy.
Then I lay in the honeycomb into the cold wet laminate to allow for nice bonding bridges between the laminate and the honeycomb.
Close the vacumm bag and continue the curing.
Inner laminate preparation:
Infuse prepreg on a table and cool it in the fridge.
Inner laminate:
Paint the the first prepreg layer with cold epoxy that is going over the honeycomb. And all succesive layers just as I take them out of the fridge after condesation has happened.
Vaccum bag everything.
What do you think about this process? Do you think cooling the very low viscosity epoxy makes sense or would you instead add some kind of thickener to the epoxy to avoid absorption and improve bonding to the sandwich.
I have experience in working with honeycomb but in nautic applications, where my live isnt at play and I wasnt that worried with laminate-sandwich shear.
I have no infusion experience. Do you think I can unpack the vacuum bag without creating chaos in the wetted laminate.
