Mineral wool is good for 230’c+ before encountering any problems.
Lagging your oven in this way is not only to stop yourself from being burned! It:
Cuts down on your fuel bill dramatically.
Heats the part and not the workshop for your own comfort in Summer…
Will get up to temp quicker and hold it easier.
Acts as a fire barrier.
I would recommend getting it in slab form: http://www.thermatechinsulation.com/Pictures/Rockwool-Board.jpg
For what we want it is perfect - cuts easy with an old carpenters saw or knife, holds its shape and you can clad it afterwards with more insulation board or just some fireboard because of the rigidity it has.
I’ve recently come up with what I think is the ideal solution for us to make our own ovens cheap and safe, I would like to share it and I hope you guys can get the same materials near you.
Here in Europe we make partition walls from metal channel, plasterboard and insulation, this stuff is childs play to construct and needs not much more than a pair of tin-snips, a cordless drill, a knife and saw…
Have a look at the PDF here, it will explain more than I can: http://www.fmb.org.uk/information-and-help/publications/masterbuilder/2008/september-2008/features/?entryid20=3331
Or do this search ‘metal stud partition’ for more info:
http://www.google.co.uk/search?hl=en&safe=off&rlz=1T4DVXA_enGB311GB311&q=metal+stud+partition+&btnG=Search&meta=
There are several grades and thicknesses of plasterboard, in general 1/2" gives 1/2hr fire protection, double it gives an hour etc, there are also specific grades like one which is 15mm and gives one hour of protection. If you wanted something even more sturdy and fire resisting then there are other types of material, just do a search for ‘Fire resisting board’: http://www.longandsomerville.co.uk/custom/shop/category?categoryID=567
As you see it’s more expensive, but then we are talking about potential fire hazards here.
I would strongly recommend fitting a smoke detector/alarm in your workshop, especially if it is in earshot of you or anyone else when you are not in there.
