Right, with the flow media cut a piece 12mm inside the actual finished part line/ridge dont overlap it there its not neccesary plus id be a bit worried it might bridge, then cut a strip to go under the resin feed about as wide as you have there over the ridge and ontop of the flow media already laid down. Ontop of the resin feed place another piece of flow media this will keep the resin line open, then peel ply ontop. Make sure you spray some 77 tac adhesive down before the first layer of carbon and ensure it conforms to the mold (no bridging)you can use a wooden popsicle stick to do this, do the same with subsequent layers. Also make sure the small piece of flow media to the resin feed and peel ply doesnt bridge. Youve got no ears in the bagging material but as this is basically a flat piece of carbon this should be ok, just mske sure when you pull the vacuum the bag conforms to the shape with no bridging. What i sometimes do is use my heat gun at this point and run it over the edges just to make sure the bag is into all the corners/edges.
Right at risk of repeating myself but i so want this to go right for you. The order is carbon, peel ply, flow media plus a small piece of flow media and peel ply over the resin line.
The West epoxy will be okay but do as i said and heat it and the mold first, heat the mold from the underside though. The West is a little thick and must be heated otherwise it`ll have trouble flowing.
Try and get the resin trap to seal 100% otherwise you wont know if you have a leak in the bag or not, as you know air is the killer in carbon. I did another part yesterday afternoon, pulled the vac and infused perfect shut the vac line and resin feed turned the pump off and shut the garage door. I checked this morning and the vac had lost 2mbar in 13hours and i bet thats only due to temperature change. Try and achieve that and you`ll get perfect parts every time.
Best of luck m8, let us know how it goes.
Baz
