I am making a panel that should be lightweight and stiff. The panel will be 4" x 25" x 25" and will be exposed to water.
My plan is to cut 4" polystyrene sheet to the outline shape that is required. Next I will cut the outline shape again where I want my stringers. I glass (using epoxy) each individual section with one layer of weave before re-joining the pieces back together to form the outline shape. I will then glass another layer of weave over the whole thing. I would like a smooth surface on both sides and I am thinking if I clamp the foam and glass between 2 old waxed kitchen worktops it should give me a good finish . Once cured I will drill a small hole in each section and pore in acetone to dissolve the polystyrene leaving the hollow shape with stringers. I am dissolving the foam because some parts of foam surface would be exposed to water and absorb making it heavy.
Will the cut foam make the surface uneven? I am hoping that the clamping will give me a good surface on both sides. Any feedback?
Thanks in advance.
). Any other ideas?
