Hello,
Im struggling to find a tooling “wetlay” system (resin and gel) to handle 200 degreesC. The main issue is i need a system i can do an initial cure at 40-70 degrees as the customers pattern wont handle much more safely. I can find good prepreg systems but i cant autoclave the pattern incase it becomes unstable and the oven cured systems are a little hit or miss. The last thing i want to do is damage the pattern and also risk alot of expensive materials as the prepregs i have found have MOQ’s of 50m!!
If anyone knows a good epoxy system or similar in the UK that can achieve a TG of 200 (min 190 - 210) after post cure then i would love to hear from you…
cheers
Clavemonkey
