High temp infusion resin
Hi,
Does anyone know of an epoxy infusion resin with a Tg of around 120 degreesC or higher which can be sourced in the UK in small quantities? I’m currently using a high temp laminating resin but it’s very thick, so isn’t flowing so well into the part.
Theres a few if you have post cure capability or are you looking for a Tg directly from room temp infusion? Most high Tg resins are infused at 40 deg C as opposed to 20 deg C room temp.
I can post cure. I could infuse at 40 deg C with a bit of imagination.
Araldite options from Mouldlife, Sicomin from Matrix prob a good place to start first, hope you get sorted
You can try with RenLam LY 113 / HY 98
