I’ve had a number of requests to repair cf bike rims. I’ve turned them away simply because I can’t find an epoxy that can handle my requirements. During breaking, parts of the rim can easily reach 250°C. Unfortunately they can’t be tempered once they are made because there is always secondary bonding somewhere (spokes glued to rim or hub). During manufacture, this is done after tempering the rim and if you were to re-heat the whole wheel up to 250°C those bonds would come loose. My question:
does anyone know of an epoxy suitable for wet layup that hardens under 80°C but has a Tg > 260°C?
, you could try to make a surface treatment on the rim where brakes work, with the aid of special coatings; this solution is widely used in aerospace and racecar sectors, where is necessary to shield carbon fiber laminate from high temperature sources.
