Hi Folks,
Having a difficult time finding the answers to my questions. I want to make a High Temp 2 part female split (clamshell) mold for carbon bicycle chainstays and seatstays. Parts will be made from Prepreg 275F cure. I can’t seem to find any reference materials or info on how best to do this(make high temp carbon molds that is), and wondering if anyone has any suggestions. I’ll be inserting a bladder for pressure.
I plan to make the plug out of wood and layup the carbon over that at room temp using ez lam High Temp epoxy and gel coat from acp composites in CA.(then post cure). I read somewhere that my mold should be 3 times my part thickness. SO. . . this means that I would have molds approx. 3/8" thick or 20 layers of 2x2 twill (.019). Can I just use twill for a mold, or should I be using uni as well? Any stiffeners, or “bulking agents” that are used in instances such as this to reduce the layering and build a stronger/thicker mold? Anyone tried this, and how many layers at a time, 10 and 10?(if just carbon alone).
All the molds I’ve made have been milled from aluminum and very small. So this is a new endeavor for me. Appreciate any help. Thanks.
-M
