hi … my names’ Leroy in tennessee … i’ve been an autobody and paint guy 10 years … but am moving into producing my own composite parts instead of taking collision work … i’m familiar with fiberglass and have repaired countless dually fairings and trim pieces … but have never made a mold … i am starting with a cutom grille and have the plugs made .
here’s my dilemma … i have been collecting everything i need to make my first molds … and researching how to make the mold … i think i have a good idea … i have been designing plugs for 4 months and they are complete less final wet sanding and buffing out with wax…
i have partall 10pva … orange tooling gelcoat … glass mat … rollers … acetone … all ready … but i was unable to locally source a 2lb tub of partall wax
my main concern being a auto body painter for 10 years is obviously fish eye prevention and paint adhesion after demoulding the pieces … i know well enough the dangers of silicone and it’s scurge on all things paint …
i would really prefer to use the correct wax with the pva … but can i substitute another wax for making my molds and parts … or will this create a problem ?
i would like to spray the pva if it will lay down in the mold well without running … most are 4 inches deep … narrow and with angles … i am guessing it’s somewhat like urethane clear coat in how it lays down … correct me if i’m wrong … also i read here in these forums that a corner of a t shirt rag wiped works well too … so if the sprayer i got dont do it … that’s the plan B …
so i was thinking … based on the suggestions i read in a previous thread … that using either mothers California gold ‘pure’ carnuba wax … or meguires carnuba wax … might work … does anyone have experience with these ? can i spray down the pva over either of them without it beading up … and is there any more desireable atributes that i should choose one over the other … or is there something better i can use available locally at a parts store … or should i keep trying to nail down partall wax#2
also when i go to layout my plug molds the feller i got most of my materials from was suggesting how i build the mold … he said to make a thin bead of play dough and make a radius around the top (bottom) edge so the mold has a taper not a straight 90 … is this correct … about how steep of an angle should i make this radius ? 1/8 inch … 1/4 inch ? should it start at the bottom of my plugs or at the top of the side of em ? any advice on how to construct the mold is appreciated … he suggested 3 layer … 4.5 in 1 1/2 mat which should be about a 1/8 inch mold … which seems kinda thin to me … but is that appropriate ? said because the intracacies of the contours it would release easier not being too thick … but i also would like it to last awhile … what do you think?
also he suggested using wax paper under the mold … is this a wax paper layer on top of the play dough or can i smear wax and then pva the playdough and build right on top of it ? is there a better way to make the edges and how should i layer the PD / wax paper ?
should i cut the mat to my paper paterns before hand and how much should the strand mat overlap on the first layer if at all ? someone online suggested in a previous thread not to overlap the edges of mat on the first layer because heat will cause distortion … but at the supply warehouse the mold maker said it’s not a problem … overlap with mat is okay on a small part he said so that’s a conflict of advice … but i tend to go with what an expert says over an old internet article …what say you ?
i think i will be paintbrushing the tooling gelcoat … should i just apply 1 thick … even layer … or 2?
also i didn’t get any literature with the orange tooling gelcoat … does anyone know how many drops of mekp this should get per ounce?
i have bondo resin but he also gave me a mistery tub of resin … i can’t find any information about it online even on the manufactures website… if anyone knows about this please let me know … i will tell you what the label says … polynt composites 970g353c-qm pirogue green material# 924071 ((contains: diethylene glycol, titanium dioxide) i can’t imagine it’s just those 2 ingredients … but for what it means thats what it says?) i got it from advanced plastics …
They were very helpfull and had everything i needed … Though they don’t sell the tooling gelcoat or resin in small batches they were kind enough to give me a small amount of each as a sample … As the saying goes … You don’t look a gift horse in the mouth … So … I didn’t even look to check for any literature and there’s nothing to go by except what’ labels on the resin tub … And the tooling gelcoat is a plain can … so that’s what that’s about …
any tips / tricks are appreciated
thanks in advance for your replies and assistance …
