Hi everyone, I bought some cheap carbon cloth off a friend of a friend who was clearing his garage out, i taught myself the basics and made some flat sheets which turned out well apart from the 3 day cure time which I will discuss later. I have since done some race car body work at university which made me want to create my own molds and parts;I decided to try and and make a small part for my friends bike as shown in the photo.
](http://s1230.photobucket.com/user/Niebz/media/IMG_0122.jpg.html)[/IMG]
](http://s1230.photobucket.com/user/Niebz/media/IMG_0123.jpg.html)[/IMG]
I then set the part up ready to take a mold using modelling clay from easy composites. I didnt take a photos of the actual set up but imagine this all the way around.
](http://s1230.photobucket.com/user/Niebz/media/IMG_0126.jpg.html)[/IMG]
i then took the mold which left some messy edges where the clay was, but the finish wasnt too bad on the face that matters. There were a few holes which I filled in with some epoxy araldite and sanded.
](http://s1230.photobucket.com/user/Niebz/media/IMG_0127.jpg.html)[/IMG]
](http://s1230.photobucket.com/user/Niebz/media/IMG_0128.jpg.html)[/IMG]
The mold was sanded with 1200 as the final grade. and waxed with this.
](http://s1230.photobucket.com/user/Niebz/media/IMG_0134.jpg.html)[/IMG]
once laid up with 2 sheets of 280 gsm, one larger than the shape to do the walls, then one to fit inside, I made my first shaped piece of CRP.
](http://s1230.photobucket.com/user/Niebz/media/IMG_0135.jpg.html)[/IMG]
](http://s1230.photobucket.com/user/Niebz/media/IMG_0138.jpg.html)[/IMG]
As shown in the photos the part has a dull surface finish and air bubbles at the side.
I have suspicions that the following could be causing the problems.
-Mould not sanded to a fine enough finish
-Carbon un-peeling its self from the corners however without a vacuum i cant see a fix for this?
-No gel coat applied. When i went to do a layer of resin to let it set, it was repelled by the wax and wasnt even and grouped in puddles so i laid straight up with the carbon
- Also there is resin build up in the corners where there is no carbon.
- a cheap paint brush was used to stir it, which could be airing the resin mix with bubbles?
Heres a photo of my set up in my garage
](http://s1230.photobucket.com/user/Niebz/media/IMG_0125.jpg.html)[/IMG]
I had previosly used this epoxy resin for the sheet however it was quite expencive and also took ages to set properly, It cured in the living room balanced on top of a radiator never went fully hard like the polyester im using, it went gummy and flexible.
](http://s1230.photobucket.com/user/Niebz/media/IMG_0132.jpg.html)[/IMG]
So yeah, this is my first post, and my first carbon project rather than sheet. If anyone could provide any help or confirm my suspicions it would be muchly appreciated.
Tom
