The carbon fiber knives that have carbon fiber blades are gimmicks, the blades cannot stay sharp. CFRP (any FRP really) doesn’t have the hardness of metallic materials. Cosmetically though I would think a carbon shell on a swiss army knife could do well. There are a lot of weapons enthusiasts who would go for it. That would be an easier business to run as well, since making each specific tool on a Swiss Army Knife would be a real pain
Edit: HOWEVER!
Something I’ve never seen before: A knife where the entire body, and most of the blade itself, is made from CFRP, but the knife edge of the blade is sheathed in some sort of metallic. You could then sharpen that edge into a actual knife edge that would stay sharp, but have the weight savings benefit of having a knife body, handle, and blade support/backend (sorry - don’t really know the technical terms regarding the anatomy of a knife) made out of CFRP whilst still allowing it actually cut something. This would follow in a similar vein to which GE manufactures its large jet engine blades - most of the blade (indeed, all the load bearing components) are made out of CFRP, but they tip the edge of it with titanium so debris and FOD doesn’t destroy the leading edge of the fan blades. Makes repairs easier too since you can just weld extra titanium to add any lost material.
^There is probably some real commercial value in that, so if you start that business and it takes off, I expect you to buy me a drink :cheers:
