What method are you using to cure it? Oven, Autoclave, press?
Several of my employer’s customers use it, but only for autoclave. I am currently helping solve some porosity issues right now with it, but I can’t really talk specifics on it. What I can say is it would make a horrible out of autoclave system, unless you use a press and manage to keep the resin from bleeding excessively. It needs high pressure to reliably produce low-void parts.
If you are doing out of autoclave and can still change resin systems, I would recommend Hexcel’s F263 prepreg or Cytec’s 5276-1 prepreg. I am not at liberty to say why this is the case, but they both are far more forgiving than 8552 both in and out of an autoclave.
