Hello everyone. For a while now i have been trying to roll prepreg tubes for my hobby which is high power rockets. I’m using dunstone 120R sample tape for compression and a homemade curing oven with an arduino based temp controller.
I bought some 5.7 ounce 2x2 twill prepreg to roll tubes with. The manufacturer said it has a 38% resin content. But i calculated more at around 40-45%. Here is the prepreg data sheet.
http://www.orcacomposites.com/Orca%201425%20Pre%20Preg%20Resin.pdf
Yesterday I rolled my first tube with 3 layers to try and get a nice smooth and uniform finish with heat shrink tape for compression. My results were was not what i hoped for. I got significant dry spots in between the fibers at the surface of the tube. I believe it is called print through, but i am not sure. Also the mylar was not peeling off very well so i don’t think I’ll use that again.
I have a couple of theories:
1)There isn’t enough resin to get to the surface of the tube.
Or maybe the resin is curing before it can run fully throughout the part.
I followed the highest curing cycle the best I could. Ramp up, hold at 310F for 1 hour, ramp down.
The three pictures are shown, the first one is the surface of the tube. The second one is the prints the resin made on the mylar. The third is the 6" long tube in its entirety.
Do you guys have any suggestions on how get a nice smooth finish on these tubes? I would hate to add more resin to the tubes.
Thanks,
Tom
