I have been researching interlaminar flow media for some time now and am at a dead end.
What I need is a very thin flow media what I can put inbetween carbon fibre laminate layups in closed moulds to produce a double sided glossy finish. I also want to infuse double sided glossy panels in one hit. These are generally turned into machined items so I cant have an obvious discolouration or bits along the machined edge.
The usual airtech flow media works great BUT unfortunately has no strength characteristics when used like this and delaminates.
spoke to all the major players and no luck, incredible that no one seems to have a solution for this.
is there anything glass fabric based that would do the trick? someone mentioned a dissolvable flow media but was very hush hush. Even the RTM boys dont have anything special to use.
