I’m interested in building a simple structure out of a fiberglass over a structural urethane foam core. For those who are familiar with guitar amp construction I basically want to build a combo amp cabinet carcass. For those who aren’t familiar this is basically a rectangular “box” shape with four sides (front and back are open).
I would like to use carbon fiber or this “black fiberglass” I’ve seen but will not be making any molds since this will likely be a one-off part.
So, is there a good way to achieve a durable clear coat on top of a layer of woven fabric without molds and vacuum bagging? Anything I can brush or roll on? Are automotive clear coats sufficient?
As for the structural construction my plan is to miter the edges of my foam sheets and join them together with hot glue. Next I’ll cut notches to insert wooden strips to use as “hard points” that I can screw into to install the front baffle and back panels as well as some wooden dowels for other small mounting points (handles, chassis, etc…)
Once the foam is fully loaded with its wooden hard points I plan to glass all the corners with tape and the follow up with two layers of regular 4oz cloth all cut tight to the inside dimensions. Then the outside face will be covered with one layer of 4oz glass and an outer layer of either carbon fiber cloth or black fiberglass for the “look”. This top layer will be cut a bit larger and wrapped around the edges to overlap with the inside glass and dress up the sides of foam. Obviously I’ll be using epoxy resin due to the urethane foam.
So, any major problems with this approach? My goal isn’t absolute lightness… I just want something lighter than the standard plywood carcass and at least strong enough to let someone sit down on it without cracking in half
Sorry for the long post…
I appreciate any advice the group can give on this project.
-Matt
