Hi all, I have just been reading a thread started by CarbonMike about him getting air in his infusion. I think I am getting the same thing (excessive draining). Can you end up pulling the resin out of your part if you leave the pump on to long? How can I ajust the pressure of the vacuum pump? I can leave the part for over 24hours with no drop in HG so theres no leaks. This is mikes thread http://www.compositescentral.net/showthread.php?t=3582
He only says he clamps off the outlet tube once the part is infused. Would this leave excess resin in the part? Any help will be very helpful
Just thought I would add there is some writing on the part I am making and the cloth doesn’t sit fully into it. Should this not just fill up with resin?
