Hi
I’m new to this forum, and have some questions, i hope you can help me with.
The project is to make a costum made shinpads for soccer. (kind of like these http://c6agility.com/), other posts about this on the forum, did not answer my questions.
On the inside of the “shell”, there is going to be a layer of soft poron-material/foam (2-3mm thick).
First question is about the mold.
Do you have any suggestions about which material is best used to create a mold? My first thought was to make a mold directly on the leg, with plaster bandage. And then make a mold of the inside of the plaster mold. But then the finished product, woould be to small, because of the layers of fiber and the foam inside.
Any good advice here, on technique and material?
My second question is: Which material should i use?
-Carbon Fibre 2/2 Twill
-Carbon Fibre Plain Weave
-Carbon Armid 2/2 Twill
-Black Diolen 2/2 Twill
-A combination, or a different materiale?
I’ve read that Carbon fibre could shatter in case of a hard direct impact, so this made me think if there is any another combination of materials, best suided for shin guards.
Thanks in advance
