How Do All,
This is my first post so also my Hi! post. Hi!
I have a small oil filled vacuum pump which I am using for vacuum bagging carbon parts, I have just recently bout an SMC lossless vacuum regulator from easycomposites in the UK to use with this set as I was finding that thee vacuum was too high with the pump alone and this was bleeding my parts of too much resin.
This new vacuum regulator seems to have a problem, that when I set it to say - 0.6 bar, when it reaches this the pump does not seem to go completely quite as normal and the vacuum will all of a sudden start sucking and shoot the needle off the gauge over -1 bar then slowly drop to the -0.6 bar setting again. the regulator seems to be just randomly doing whatever it likes.I am just wondering if anyone can enlighten me as to why this might be happening?
there is no leaks in the system and with the regulator removed a total vacuum can be continuously held without the pump working up a head of oil vapor.
I also have a small storage vessel in the line but this dos not seem to effect the operation with or without it.
below is a link to the regulator set I bought.
Any advice or help is much appreciated.
Take care,
Barry.
