I’m getting ready to get my feet wet and try some core material in my lay up. I understand the concept of the added thickness making the part stronger with less weight but everything else im uncertain of.
-Is there a different core material for wet layup vs resin infusion or are they all the same?
-When you laminate the core material, does resin saturate it? What happens when you cut through a laminate through the core? will it flex when you pinch it? or are you suppose to make the core slightly smaller and cut around the core?
-how does honeycomb work? In my mind the voids would just be filled with resin making the part even heavier…
-Can you use foam core from an arts/craft store? I did a test layup with this and it seems to work very well, but im worried at a larger scale, the piece will act almost as if it was hollow sins the foam between the poster boards are not dense…
Also anybody have links/pictures of the layup process (wet layup)
thanks in advance!
