I’m new to composites work for the most part. This will be my second project. My first project was abandoned over 10 years ago, and I’ve got a newfound interest in making composites parts. I’m an engineer and a very hands on person, so this sort of thing is right down my alley.
This particular project will be to produce a lightweight composite sunroof delete panel for my autox car. I’d like to fix it permanently to the roof. I have an existing metal sunroof to use as a plug, with a few modifications. My sunroof fits flush with the roof, and is sealed with an edge seal. On the inside of the sunroof there is a gutter type features to catch and drain any water that makes it past the seal. I want my part to overlap the roof by ~1" and be adhered/sealed to the roof, thus eliminating any edge seals and gutter system.
Here is the sunroof hole.
IMG_4930.jpg by Kevin Sobkowiak, on Flickr
Another of the hole.
IMG_4935.jpg by Kevin Sobkowiak, on Flickr
Closeup of the hole.
IMG_4940.jpg by Kevin Sobkowiak, on Flickr
Sunroof to use as plug.
IMG_4941.jpg by Kevin Sobkowiak, on Flickr
Now here are my questions.
I can’t use the metal sunroof as is for a plug, I’ll need to extend it ~1.5" in all directions so it will overlap the roof. I was thinking about various methods of flanging it and filling it with clay, but I’m not sure how I’d get a perfect contour/surface to use as a proper plug. What method would you recommend?
I’m planning on using vacuum infusion for the part, using 2 layers of 6oz twill weave carbon, then 1/8" divinymat core, then 1 or 2 layers of 6oz twill weave carbon in a sandwich. The core will not extend all the way to the edge that will be sealed down, just in the large mainly flat area in the middle. Would you do 2 layers, core, two layers, or recommend some other layup schedule. I was somewhat curious if 2, core, 1 would be adequate for a sunroof.
What method of attachment would you use to mount it to the roof. The seal must be waterproof, that is a requirement. I have thought about using self-sealing rivets, and using RTV between the roof and composite flange. I’ve also thought about using roughing up the roof surface under the overlap and using a structural epoxy, but I’m not sure how well it will bond and deal with chassis flex. I don’t want the part to fly off at high speed, so I’m not sure about that method. Any thoughts or recommendations.
