I am working on a custom CF project in my garage. I’ve recently done a lot of sanding and shaping by Dremel and by hand. I wore a mask to protect my lungs, and I did all the sanding in the corner of the garage furthest from the door to the house, and where all our stuff is stored.
But despite my efforts, there is now a thin film of black dust covering every horizontal surface in the garage, even those in the opposite corner from where I was working. It’s even getting tracked into the kitchen no matter how many times I wipe my feet before I come inside. It’s like a VIRUS.
I realize there’s probably no magic solution to this situation, but was wondering if anybody had any ideas other than (a) dust everything with a wet rag by hand (tons of boxes, tools, even canned food shelves) or (b) get a leaf blower and try to blow it all out the door (somehow I think this is not as good an idea as it sounds, would probably just re-distribute the dust and knock my stuff over).
Any ideas? Thanks!
Could probably buy a used dust collector system somewhere. I’m thinking like a thin sheetmetal top with a thousand holes drilled in it, then supporting it an expanded steel mesh. This way the part can slide over the surface of the table without getting hung up on the expanded steel mesh.
