Good evening, everyone!
I am looking to begin building a new vacuum system specifically for infusion. I want to build something that is going to be very user friendly, and works well.
This is the vacuum press that I made for bagging wet lams.
I have been looking into using the follwoing pump for use with this system.
Yellow Jacket 7CFM bullet: http://www.amazon.com/Yellow-Jacket-93600-Bullet-Vacuum/dp/B003AJIWOY/ref=sr_1_2?ie=UTF8&qid=1356149067&sr=8-2&keywords=yellow+jacket+vacuum+pump
Are we feeling that this pump is going to work OK?
I know that there are better choices out there, and I am all ears, but my budget for a pump will need to stay in the $500 range right now. If anyone has any suggestions for a different pump, please let me know.
I am on the lookout for a new pressure vessel such as an old air compressor tank or something similar. I also have the option of making tanks out of PVC like the ones below.
I used the plans and materials from joewoodworker.com for my existing vacuum system. The plans are great and my current system is very solid, but the pump only pulls around 25". The vacuum switch also leaves a lot to be desired.
As far as switches go, the SMC switches look nice, but complicated to wire up from what I have read on the forum. There are also a lot of different models out there. It would be great if the experts could chime in with specific suggestions of switches that have proven to be durable, accurate, and somewhat straight forward to wire into the system. I’m in the US, so suitable sources would be great too.
I think that’s pretty much the jist of it, right? We need a good pump, a vacuum switch, some sort of pressure vessel, and the rest is really support gear and basic wiring.
I know that I am asking a lot here, but If I can get the parts scrounged up, I’ll be happy to put together a detailed toutorial of the building process as a way to say thanks, and pass the knowledge along.
Thanks for the help, everyone!
