Hi,
I tried wet lay and vacuum bagging of carbon fiber composites for the first time for a friend. Fuselage for RC planes and canopy for his old quad copters.
Process:
Made fiber glass moulds for the parts
Used either hand lay up or vacuum bagged them.
Slow 24 curing epoxy resin, no heating or any other curing process.
Fabric: 240 gms to 280 gsm twill CF
FRP release wax used as release agent.
Another liquid release agent also applied over wax (probably PVA but not 100% sure)
For vacuum bagging used both traditional method (vacuum on one side, mould on another). This method caused the mould to flex or warp.
Other method was to put the mould and fabric directly in a bag and seal open end. In this case vacuum pressure is on both sides. No flex or warp of the mould under vacuum, no leakages.
First I apply release wax (at least thrice per mould with 15-20 min interval). Then added a thin layer of PVA by hand/sponge. When I use PVA surface finish seems worse, tends to stick to the body.
Pure wax release agent without PVA is much better.
For the fabric, I tried both methods, first wherein we drape the fabric in mould and then apply resin. Second much better method was to apply resin to fabric first and then drape the wet fabric into the mould. Apply excess resin as required.
Please have a look at the pictures.
Issues:
- Wrinkles. No matter how careful I am I still get wrinkles in what I think are perfectly simple surfaces. This is a problem in vacuum bagging
2)Fabric not sticking to the mould. Even under vacuum bagging with no leakages, there are certain areas where the fabric just does not stick to to the mould. Even on relatively smoother curve surfaces the same happens.
Finish:
Had pin holes initially. Started applying resin to the mould and the problem solved. But it started another problem of sometimes the extra surface resin sticking rather onto the mould then the actual part. So get some shiny resin rich areas and some mat finish type areas.
Also seem to get cloudy surfaces. -
Fabric overlap areas: Since fabric does not drape well over all surfaces, I tend to make cuts at points of wrinkles. The cuts look shabby externally, specially in wet layup. In wet lay up they also tend to stick out and I got a bad cut while handling it. Any method of avoiding messy cuts or making cuts cleaner?
The finish is quite ok as a mat type finish at some of the better areas but I want a glossy finish. Adding Lacquer or clear coat will be better but I need to sort out the above issues first.
Thanks in advance.
