Well, I’m Rob.
Hi.
Now, I do love composites - have a particular fondness for a good 2x2 twill weave CF. That all being said though, I have worked very little when it comes to small, intracate things. Which is why I’m here. I’ve got a bit of an intulectual dilemna:
If you look at the attached files, this is the foregrip of a little something I’m working on. All well and good, but I have no idea how to make this very intracate shape out of carbon fiber.
Some of the problems:
It’s got a huge hole down the middle of it.
Fillets.
At the thinnest part, it’s only 2.75mm
Plus, it has to contain 300psi. I know it does in aluminium - carbon though? The pressure in contained in the form of a screw-cap in the bottom of the piece. I don’t even know if you can cut threads in carbon fiber.
Any sorts of guidance would be a huge help. This is the most intracate thing I’ve even considered doing in CF.
Rob
