Hi guys
I am currently building the moulds for the wings of an ultralight aircraft (5,5m x 1,5m).
Still not sure if I will use low temp prepreg or resin infusion.
However I need to postcure the laminate in the molds at least at 80ºC ideally at 120ºC.
I thought about using some aluminium foil to radiate the heat evenly.
On that aluminium foil I paint high temp silicon with an impregnated layer of fiberglass.
When dry, I would lay at 1cm spacing parallel 0,2mm tungsten wire (doesnt shrink with heat)
On the wire I would again paint high temp silicon with an impregnated fiberglass cloth.
On this last layer I would glue some thermally isolating mat.
Questions:
Does silicon bond to dry silicon?
Any alternative idea for the first thermally transmitting layer ? (thought about aluminium, but think it could be very delicate)
Any cheap high temp silicon provider?
The last layer could be rock wool, but rock wool is very dirty. Any suggestions on this?
Any suggestion with the wire?
- would need to be waterproof though
