Ok . … i made some thoughts and i would like your aid + positive criticism . Until now in some bicycle repairs repairs i did i used
easy composites shrinking tape with good results . Problem is that
i dont know how much pressure it gives to the pipe of the bike it is
being repaired so i looked to this supplier which has proper data sheets.
http://www.shrinktape.com/products/hi-shrink-tapes/Hi-Shrink-Tape-300-Series?p=312R
The principals of my choice are the above :
The cure of the prepreg material for the repair will occure at 180 F .
At 180 F the tape (see man. table ) will give pressure of about 6.4 lbs/ (1.20 cm X 2.54 cm )- (see man. claim of lbs/inch of width which i believe goes for the standard model of 12mm ) which is (6.5lbs*0.435) 2.94 kg/ 2.84 cm2 = 1.04 kg / cm2 which is close to the 0.94 kg/cm2 of the - 0.94 bar vacuum force .
So in other worlds if i put this tape around the pipe of the bike it will apply force at 80 celcius about 10 % more of the force applied by vacuum .
There are 2 things i would like to ask :
Is my theory right ? - apologies for the randomness of thinking
This force is applied if i wrap around one time the tape ? And if wrap it twice what happens ? it doubles the amount of pressure and 3 triple ? Until i reach the limit of the material ? And how do i know it ?
