My application is bonding prepreg tow (formulated with EPON828) to wood that has already been pre-bent to a specific geometry with heat, about 115C. The tow manufacturer calls for 135C for 4 hours, which would obviously cause my wood to relax and lose its shape if I were to apply the pregreg to the wood and then heat cure. I need to cure the prepreg once applied to the wood in some other fashion other than heating the whole piece of wood for a long time.
My question is, are there issues with applying multiple passes of high heat, with cool cycles in between? Would the prepreg eventually cure cumulatively from short passes of high heat?
