Ouch!!!
You are very bad luisn:p , why you said that:confused: ?  Off course I don’t have a problem to explain the way to do it. The only problem is the work that I must find free (because now I have two works) time and the second which is serious, is my English:( .
Any way,
The way that I fab’d the headlight is with “Akylon” (something like Teflon, but not)  I cut it in very small piece and then I cut it us the fabric mount. The think is that takes a lot of time to fix it but in other way you have very – very strong mounts. Now the way to stuck on it is very easy:
a)	On the fairing put carbon-kevlar cloth and polyester or epoxy resin 2 – 3 layers around the area on the fairing. Wait to cure.
b)	Take a super glue of two chemical ingredient and put plenty on the Akylon and plenty to the fairing. Wait 30 seconds and stuck it. You must press hard to stick very well. The reason that we use Akylon is because there is no any oil like Teflon. When you put this glue, don’t be ware for the rest of the glue, just with your hand split it around the Akylon and fairing. You must do that for the © reason. Wait for cure at least 2 days.
c)	Then apply to the rest of the glue carbon-kevlar cloth and resin and cover whole glue, around the Akylon  and some area of the fairing to be 100% strong with whole fairing.
This is the strongest way that I am using this moment. I fix a lot of bikes with this way and there is no problem.
The push pins I make it with the exactly way but I send it to cut it in turner shop. In the touching side with the panel I’ll just make a bigger radius for a better stick witht eh glue.
This project take me over 4 months to created, many wastes panels.
Now about the stripes. Each faing on the front there is 2 kinds of cloths, Titanium and carbon. The way to done a perfect line you must take a pen and draw on the mold when you have already cures the applied geal coat. Then you just cut the cloth as your way and put it on the mold. Now if you have a big fairing then you use two carbons sheets. One in the left side and ont on the right side. The connection must be in the middle because there is a small area to see someone the cut. If you see in very close the fairing you can see the cutting line in the air-exhaust. You must have patience and you must very cool.
Luisn, if you see my web site, all my products have inddor photos and outdoor photos. This project I forget it.
About the cloth for the back panel I make it with two people. The mold is in two pieces. I will put some old photos how I make it.
Any questions?
