A friend of mine is interested in one of my spoilers that I cast by hand, but instead of wanting one out of fiberglass he wants one made using carbon fiber. I have never worked with carbon fiber in a mold before (only overlays), and I figured it would work best if used with infusion and or vacuum bagging versus hand layup? (I dont have either of these more advanced methods setup) I dont own a compressor or a spray gun so everything is done all my hand and a brush.
I am afriad of ruining his carbon that he has sent to me because I am not sure how well it will conform to all of the tight radiuses/corners and interior edges by hand layup and no pressure keeping it in place. Also, is a clear gelcoat needed for a nice finish? What about laying down a layer of resin first before the layup and letting it cure before adding the carbon versus just laying down the carbon from the beggining? This is purely an aesthedic piece to him and he seems to care about the end finish the most. Does the finish of carbon fiber look clearer with epoxy or polyester?
I have some sample photos of my spoiler negative molds, showing how I typically lay up my spoilers with them open and also with them closed. With the molds open it allows me to easily get in to all the areas, but in the end leaves pinholes around the seams, versus laying them up closed it is harder to get into all the seams but leaves no pinholes around the seams at the end.
here are some photos molding it out of polyester gelcoat + polyester resin with both chopped strand mat and woven strand with the molds OPEN:
and here is a photo showing how tight the mold is to get into when it is laid up closed:
some photos of the finished part made with the molds OPEN (when the seams are sanded it reveals the resin at the seams)
