As the title states, I am experiencing air bubbles - mostly on sides and inside corners. My second effort with epoxy was much improved, as I took great care in continuing to tap those areas throughout the layup process. Is this primarily an issue of technique? And, if so, plaease make some suggestions. Or, would product selection help me eliminate these pesky air bubbles?
First photo shows my mold which I have used many times for gelcoat with polyester resin layups.
Second photo attempts to show a corner air bubble about 1/16" to 3/32" deep.
Third photo is of a very shallow void where the first layer of material has pulled slightly away from the mold surface.
