I’m currently working on a new mold and since I’m planning on potentially using VIP in the future, my thought of late has been to add a 4" flange around the whole mold. (3-peice mold of a front bumper skin).
Now, the problem with this is that since adding a flange means the mold extends past the point at which I would want to trim the part, green trimming would appear to no longer be an option.
So what should I do? I see my options as:
1)have bolt-on flange sections.
Pros:best of both worlds
cons: super complicated, potential sealing issues- maybe I should use a massive envelope bag anyways since the mold is multipiece?
2)use aluminum tape or something?
pros:no potential sealing issues or release issue
con:have to re-do the tape for every part.
3)skip the flanges altogether- super 77 the fabric in, trim it to “within sanding distance” before even doing layup or infusion
pros:no flanges is simple. fabric is pretty easy to cut dry
cons:have to be pretty exact in cutting to keep the bag from messing up the edge where the fabric overhangs.
I’m kinda think of just skipping the flanges.
Basically it’s a huge part wil LONG trim lines that are brutal to try to jigsaw/bandsaw straigt.
Smooth, straight trimmed edges seem to be the thing you immediately start to chase after once you’ve got the general process down hey?
Thanks guys. Sorry to be so long winded.
