Hi guys
Would you think i could use typical 2 layer Gore-tex Fabric as semi-permeable layer to stop resin while applying vacuum? (membrane assisted vacuum infusion) i am searching for alternatives to MTI or Airtec Dahlpac. If Gore-Tex would do the trick then I would apply it to the total surface in combination with breather cloth to have a “thickness” direction of the vacuum instead of “tube” like solution (MTI and Dahlpac).
My understanding is that MTI and Dahlpac are made of Polytetrafluoroethylene (PTFE) and so is Gore Tex (which also have the purpose of letting go water vapor and air but not water), but I might be wrong?..
Kindly let me know what you guys think…
Really appreciate thanks!
