Hey guys,
I want to buy an epoxy that can handle high end use temperatures to like 250 - 300F and have a room temp cure. I would also like to keep the cost below $85 a mixed gallon if possible. The cured epoxy needs to not be blue, gray, orange, or yellow tint once cured on the laminate - need clear other wise my customers will complain if they see a hint of color. It also needs to remain hard/stiff when the cured part is heated up to 200-250F. Also this is for infusion and needs to be 600cps or less.
I know, lots of demands from an epoxy :o
All the other numbers for this epoxy is off the chart, good stuff.
