good epoxy surface coat
I’m trying to change all my molds to all epoxy instead of using per/ver, but I’m having trouble finding anyone that carries an epoxy surface coat other than fibreglast.com(I refuse to purchase anything from that company). Does anyone have any suggestions? thanks
i use the adtech surface coat es-201-pc. about 1 hour to cure at room temp. 10 or less pot life so get to it, cause it’ll start smoking pretty quick if you play around. 100:14 PBW. for what i do, it’s great stuff.
where do you get it from?
i’m not sure, i dno’t do the ordering. let me see if i can find out. I’m prettys ure though that we order direct.
why is it so difficult to find epoxy surface coats? I just want to make some molds!
Ad Tech is owned by Cass Polymers
http://www.casspolymers.com/index.html The below companies are distributors in California that carry the Ad Tech surface coats and epoxies.
Composites one
FRp Supply,
GE Polymer shapes,
REZChem Plastics
Plastic Materials corp.
IR Polymers.
I ended up finding some of the EZ LAM epoxy surface at acp composites nearby.
Tried to get some adtech from composites one, but they don’t stock it, and would have to special order it. Doesn’t work well when I’m in a bit of a time crunch.
