I am noodling on building some bulkheads for a boat that need to be finished on both sides.
I’m curious, as someone has bound to have come up with a smoother method of getting both sides of a laid up foam panel slick at the same time, without having to do a lot of priming, sanding and painting.
I am thinking about spraying gelcoat or a finish on the glass sheet, and then laying a layer of veil followed by 17 once biaxial cloth, foam, and another layer of cloth. Vacuum bagging it to the table.
When that kicks off, i’m thinking to turn the whole thing over and lay down a coat of gelcoat, veil, and wet out the face of the 17 ounce with thickened epoxy for any of the weave that may be exposed, and plop it down onto the veil. Vacuum bagging it to the table. I’m just not sure that the air between cloth and the veil will find its way out without voids under the gelcoat.
Zach
