I’m telling you. Use Frekote 770nc or any other chemical release agent, THEN use wax. But not just any wax, the type of wax people use for PVA since some wax doesn’t bead up. I can’t tell you exactly what other waxes there are but I used this stuff called dolphin wax.
The logistics behind this is outlined below.
Step one: seal your mold like you always do with frekote or mold sealer
-Seals, I’ve just always done it but seals…
Step two: put a chemical release agent on your mold like frekote 770nc or other
-The chemical release agent is what’s going to keep things from sticking, if you use a IMC or not you use this if you don’t use PVA
Step three: put a few coats of wax, make sure it’s the wax that doesn’t bead up. A good test is that if pva beads up when you SPRAY it or runs then it’s not the correct wax
-This wax helps aid and gives just enough grip to spray the IMC on the mold. You need this type of wax because if not you would be spraying on a chemical release agent and the chances of things running and beading are a lot higher.
Step four: Spray your IMC and follow instructions.
Follow these steps and you’ll be fine.
