Gelcoat vs topcoat/flowcoat
Hi All,
I’m a little bit confused here on the above application. can top coat be used as a gelcoat? meaning we brushed/sprayed the top coat on the mold>cured and then we laminate glass on the top coat. is there will be any problem? pre released etc as the top coat is added with wax solution there is no tackiness condition> poor adhesion for the resin/laminates. your comment?
Not recommended.
A gelcoat can be made into a topcoat, but the other way round is impossible.
